Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
News
Podcast feed of member-posted sound clips!
Unofficial Warmoth
General Categories
Hardware
Piezo Pick-up routing
Pages: [
1
2
« previous
next »
Print
Author
Topic: Piezo Pick-up routing (Read 1351 times)
GuitarEC
Jr. Member
on:
October 16, 2007, 03:44:45 pm »
Does anyone here know if the Wilkinson routing done by Warmoth will accommodate the Fishman VS-50P Wilkinson Powerbridge?
After hearing a piezo pick-up in a Strat bridge, I'm thinking that would be awsome to include in a future build!
Please let me know,
Eric "GuitarEC"
Last Edit: October 17, 2007, 05:42:17 am by GuitarEC
Logged
ibob74
Sr. Member
Re: Fishman VS-50P routing
Reply #1 on:
October 16, 2007, 03:51:09 pm »
Not sure about the rout for a Fishman, but Graph Tech sells replacement Ghost piezo saddles that will fit in Wilkinsons.
Logged
GuitarEC
Jr. Member
Reply #2 on:
October 16, 2007, 04:01:31 pm »
Okay - the only issue I have with the Ghost system is I have 6 separate wires I have to route through the bridge plate into the control cavity...
The Fishman Bridge is all inclusive and has a single wire that comes out the bottom of the bridge already...
Maybe if someone out there had some experience with either / both of these systems and could enlighten me...
Again, many thanks,
Eric "GuitarEC"
Logged
tfarny
Reply #3 on:
October 16, 2007, 08:04:59 pm »
All true. But drilling a few little holes in your bridge isn't that hard of a mod, the wires are tiny and they come out the bottom of the saddles. The rest of the routing and rewiring you'll have to do is probably a lot harder than that part. I did research before buying the Graphtech, and found some people pretty unhappy with the quality and reliability of the Fishman setup. I can tell you the Graphtech is well made and the saddles are good quality. Suggest you check out the Fishman first in person if possible, instead of buying it based on the Graphtech sound. I think there are a few guitars that come stock with it - some Schecters, maybe? I forget.
Logged
GuitarEC
Jr. Member
Re: Piezo Pick-up routing
Reply #4 on:
October 17, 2007, 06:03:08 am »
Does anyone know if the holes could be small enough to allow one per lead, or would it be better to group them in twos?
Also, it's not the wire diameter you need to drill the hole for - it's the connector on the other end...
That being said, is there enough room in the body routing to allow for wiring to enter the body through the bridge plate on the spring side of the underside block? What about the 6 -> 1 block connector that Graph Tech uses in the Ghost system to mux the 6 pick-ups to a single signal connection? Enough room in that cavity to mount that there, or would I be better off routing the individual saddle wires into the control cavity?
...oh, so many questions!! ...and JUST when I thought I had my guitar's electronics figured out!!
Eric "GuitarEC"
Logged
Wyliee
Reply #5 on:
October 17, 2007, 07:53:56 am »
Quote from: GuitarEC on October 16, 2007, 03:44:45 pm
Eric "GuitarEC"
If you can get dimensions from Fishman, you can compare those against the VS100 bridge Warmoth carries.
http://www.warmoth.com/hardware/bridges/pdf/Gotoh_Diagram.pdf
-Eric.
Logged
GuitarEC
Jr. Member
Reply #6 on:
October 17, 2007, 08:15:13 am »
Wyliee,
I had already checked that, but the points of reference used on the two diagrams made it really difficult to make any determination about compatibility...
I'm thinking I'm just going to go the Graph Tech Ghost route...
Eric "GuitarEC"
Logged
jackthehack
Reply #7 on:
October 17, 2007, 09:28:05 am »
Could do a Thinline and stuff a Fishman inside...
Logged
tfarny
Reply #8 on:
October 17, 2007, 11:38:00 am »
For JacktheHack's idea; where would you put the piezo? All the main systems I've seen put the piezo in the sadddles / under the bridge. I thought a thinline was solid all the way under the bridge. Don't think you'd get much volume or a very realistic / usable tone just putting it under the top under the F-hole.
As for the dimensions / fit of the graphtech stuff, look at my previous post in 'pickups'. You can see how long the wires are. It's doable, you'll just need to buy it and suss out the details of drilling, etc. when you get the parts. One nice thing is that all the wires can be removed from the little 'connnector block' making it easier to maneuver stuff.
Logged
jackthehack
Reply #9 on:
October 17, 2007, 12:35:39 pm »
Under bridge, or under saddles on top of bridge, don't know if that would work; I'd try one of their PowerBridge tremolos first, actually...
Logged
GuitarEC
Jr. Member
Reply #10 on:
October 17, 2007, 01:32:40 pm »
Yea, tfarny - it was your thread that really sold me on the Graph Tech set-up. Out of curiosity (again, because I'm planning on mounting this on a VIP body with a Wilkinson Tremolo) do you know about how big a hole I would need to drill out (can you say 'Dremel'?) to fit those single end connectors through the bridge plate and into the tremolo cavity?
Eric "GuitarEC"
Logged
jackthehack
Reply #11 on:
October 17, 2007, 01:39:36 pm »
You should be able to just ream out the bridge ground hole already there; might fit through there already depending on how thick the Ghost wires are....
Logged
tfarny
Reply #12 on:
October 17, 2007, 06:50:46 pm »
If you drilled six holes, they'd be tiny. The wires and the connectors to the block are all about as small as can be; they're actually kind of hard to manipulate they're so small. Done carefully, I think it would be almost invisible. If I were doing it, I'd probably drill two or three slightly bigger holes and rout two/three wires through each, I still think it'd be invisible...(quick look at my drill bits)...I'd say 1/8 holes would be plenty large for 2 or 3 of those wires, 7/64 would almost certainly do it. If you've got multiple good hard drill bits and a vise of some kind, you could try 1/16 and if that didn't work, go a size up. Definitely between 1/16 and 1/8. Again, I haven't done this, but that would be my plan. Finally, just having the wires go right into the pickguard is what graphtech recommends, it's what I did, and it's hard to notice them until you get close, I guess if your bridge was black it would be more noticeable. You could do this first, then do the drilling later if the look bugs you. Again, I did this on a POS guitar body so you may care a lot more about looks if you're doing it to your dream gear. If my football team is losing on Saturday I may drill through my bridge just to cheer me up, I'll post pics if I do.
Logged
jackthehack
Reply #13 on:
October 18, 2007, 12:14:23 pm »
Note: No pickguard on VIP, carved top body....
Logged
tfarny
Reply #14 on:
October 18, 2007, 11:31:30 pm »
Oh, missed where it said it was for a VIP.
Logged
Pages: [
1
2
Print
« previous
next »
Jump to:
Please select a destination:
General Categories
=> Please Read Before Posting
=> General Discussion
=> Just Out of the Box
=> A Work in Progress
=> Tips & Tricks
=> DIY Finishing
=> Pickups
=> Wiring and Electronics
=> Hardware
=> Neck Woods
=> Body Woods
=> The Suggestion Box
=> Find a Guitar Tech
=> The Rig
=> Studio & Sessions
=> Off Topic
=> Board Member Polls
=> Gear for Sale or Trade
Gallery - * Please * Only Pictures & Comments of Completed Warmoth Projects in this section
=> Linking to the Warmoth Gallery
=> Guitar of the Month Winners
=> Strat
=> VIP
=> Tele
=> LP & LPS
=> Soloist
=> Misc. Guitar
=> JBass
=> PBass
=> Gecko
=> Misc. Bass
Loading...
