Unofficial Warmoth
Welcome, Guest. Please login or register.
Login with username, password and session length
   Home   Help Search Login Register
News:  Subscribe To New Posts Using RSS
Pages: 1 [2] 3
  Print
Author Topic: Finishing a Flame Maple Tele (56k warning)  (Read 1246 times)
DMRACO
View Profile
Ignore
« Reply #15 on: June 12, 2010, 05:01:34 pm »
1st point...THAT THING LOOKS FANTASTIC!!!!!  AWESOME JOB.  GOTM territory for sure.
2nd...I am a little concerned about the finish...you say you are using Deft...I assume the nitro stuff.  Two cans gave you only three coats?Huh?  WOW.  Spraying nitro CANNOT be done too slowly...or too thin.  I think most would recommend 1-2 thin coats a day.  If you sprayed it that quick it will take eons to cure.  If you go to sand too early...it will get all gummy.  I would hate to hear you ruin a great looking finish.  I got some good advice from Jackthehack and Tonar a while back...take you time.
I will say the deft you can work a little faster with but you still need to be carefull.  I would let it dry for a good month in a well ventilated area before sanding.  Then try a small spot on the back.  After you sand and re-shot...use thin coats.  I recently did an entire guitar and neck with 2 cans...over 12 coats on the project...
Good luck and keep up the good work....
Logged
Warmoth Custom Tele: Complete
Warmoth Soloist: Red Devil Complete
Warmoth LP: Emerald LP Complete
Warmoth LPS
Warmoth Zebra Strat
Vintage Peavey Predator-completely redone w/Kahler.
Charvel Model 6
Ibanez Acoustic
CtheHammer
New
View Profile
Ignore
« Reply #16 on: June 12, 2010, 05:21:41 pm »
I say two cans because I have two run down cans after the spraying however that is between both the body and the neck, plus the usual overspray as I move the can over the surface, some of the first can went to sample boards and I am not running any cans to empty for fear of spitting as they run dry.  But yes, I might have been a little heavy-handed so to speak...
I probably should slow down some.  I would hate for it to look this good only to ruin it through my own impatience, eh?
Logged
DMRACO
View Profile
Ignore
« Reply #17 on: June 13, 2010, 03:12:55 am »
just make sure it is dry before you sand.  Do a little test area.  Looks great!!!!  I love the color.  The best thing about nitro is you do not have to sand until the very end.  Each coat "melts" into the next.  If you are ahppy withthe smoothness of the finish...let it dry and do a final sand and polish.  I would let it sit at least a month
Logged
Warmoth LPS
Warmoth Zebra Strat
Charvel Model 6
Ibanez Acoustic
Cagey
View Profile
Ignore
« Reply #18 on: June 13, 2010, 04:53:33 am »
I kept looking at that last picture, wondering why in the world you would have taped off the rearward half an inch of body. Then it dawned on me: it's shadow from the flash I'm seeing, not tape on the body! LOL!
Looks great, though. That's a very attractive shade.
Logged
Be safety conscious. 80% of people are caused by accidents.
CtheHammer
New
View Profile
Ignore
« Reply #19 on: June 28, 2010, 05:34:43 pm »
So I have a slight problem.  I was smoothing stuff out with wet 600 grit paper when I realize that I have accidentally sanded through!
And sadly I am stupid and when I saw the spot I first thought that it was a spot that I missed...and made it worse...
So what's the fix?  Drop fill and smooth out?  Reshoot the whole front?  Reshoot the whole thing?  At this point I'm thinking I may be stuck with one weird little spot but I would still like to repair as best I can...  Any insight is appreciated... Huh?
Logged
Cagey
View Profile
Ignore
« Reply #20 on: June 28, 2010, 07:30:38 pm »
I think your best bet is going to be dye. Color match as best you can, then several rounds of clear and sanding to level it out, then continue on the way you were. Keep in mind if it's that thin there, that whole area is probably pretty thin, too, and easily breached.
Logged
MedianMusic
Jr. Member
View Profile WWW
Ignore
« Reply #21 on: June 29, 2010, 04:03:09 am »
Quote
I've "sanded through" my finishes too. Like yours, they were very small and/or inconspicuous. I never bothered trying to fix it and instead settled for the distressed/working guitar look...
Logged
Black/Red Phoenix, Blue/Black Challenger, and Green Hybrid DIY guitars.
pabloman
Sr. Member
View Profile
Ignore
« Reply #22 on: June 29, 2010, 10:10:17 am »
Use some black laquer and burst it.
Logged
=CB=
Life's grand, then you live the blues......
View Profile WWW
Ignore
« Reply #23 on: June 29, 2010, 03:40:31 pm »
use DILUTE dye.... and build the color slowly with a small brush
then give it a few drop fill layers
after those are dry, shoot the whole thing with clean again twice... let it dry and you'll be ok to sand again
FWIW, I usually dont sand back anything - no need with lacquer IF you properly fill the grain
2nd to last coat - sand off orange peel
last coat to rebuild that... and then light-light sand and buff, done
Logged
CtheHammer
New
View Profile
Ignore
« Reply #24 on: June 29, 2010, 06:06:34 pm »
Hmmm...I think I definitely had a surface prep issue on this guitar.  I did the whole dampening with water and sanding back the raised grain thing, but I didn't do any grain filling on the top obviously since it is maple and I didn't do any on the alder after reading that it often doesn't really need it however in my case it definitely did.  I must have the world's worst orange peel on top of that because while there was a shine to what I sprayed, it wasn't anything resembling smooth.  And getting it so using 600 grit took quite a bit of effort.  What seems interesting to me is that the sides came away relatively smooth though.  There was a little bit of orange peel on them (mainly around the neck pocket) but for the most part they came away smooth and with a decent surface without me touching them.  Dunno if it is a matter of how I am spraying, my overall setup, or any number of factors...
Logged
CtheHammer
New
View Profile
Ignore
« Reply #25 on: July 14, 2010, 06:13:28 pm »
Found out a week ago that I have to move a week from now so it became time to wrap up this project.  I decided to leave the spot as is; it adds character and can be a reminder for next time to be more careful.
Hardware:
StewMac Tele wiring kit
Grover Locking Mini-Rotomatics
Gotoh Tele Bridge
Roadhouse Specials for Tele
And here are the obligatory pics.  Hopefully it will be nice one afternoon so I can get some pictures in natural lighting as opposed to the fluorescent glow in my kitchen.
Did a basic set up and so far she sounds great.  The pickups have a nice full sound while still getting a single-coil sound and not getting muddy.  Overall it  .
Only one other change to make to it now, but I'm going to wait until some of the colder months to do it.  Lets just say that the basic cream dots are so...basic...
Logged
NonsenseTele
Give me pics of naked exquisite woods, please!!!
View Profile WWW
Ignore
« Reply #26 on: July 14, 2010, 06:25:57 pm »
Oh gawd!!!! such a beauty!
Logged
Brazillian nonsense bringing Chaos to the world!
kboman
certainty is for wimps
View Profile WWW
Ignore
« Reply #27 on: July 15, 2010, 02:13:15 am »
Very bling, but not overstated. The glow of the neck is... yummy.
Logged
kind of sort of maybe returning to the board, slowly
Cagey
View Profile
Ignore
« Reply #28 on: July 15, 2010, 04:51:53 am »
Nice. I like the matching neck/headstock.
Logged
Death by Uberschall
"What Keeps You Down?"
View Profile
Ignore
« Reply #29 on: July 15, 2010, 12:39:20 pm »
LoVe It, the chrome pops on that!
Logged
Pages: 1 [2] 3
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
Moonraker design by Crip
Some images provided by sloopz.
Valid XHTML 1.0! Valid CSS!
Page created in 9.527 seconds with 18 queries.
