Unofficial Warmoth
Welcome, Guest. Please login or register.
Login with username, password and session length
   Home   Help Search Login Register
News:  Podcast feed of member-posted sound clips!
Pages: 1 2 [3] 4 5
  Print
Author Topic: Mayfly BC30 review on the Gear page  (Read 902 times)
mayfly
View Profile WWW
Ignore
« Reply #30 on: July 03, 2010, 06:13:34 pm »
Here's an image
Logged
Max
This has got to be the best forum I've seen.
View Profile
Ignore
« Reply #31 on: July 03, 2010, 06:47:52 pm »
Perhaps a slightly different design for the limited runs?
Logged
Joey (Line6man): damn, that's like a perfect avocado or something
Gary Windham: Hola.  I'm making poop jokes.
Karl Boman: because I really wanted a Swede and he was willing to give it a try
(10:03:06 PM) Joey (Line6man): I run a business selling erotic hand made glass marbles
Cagey
View Profile
Ignore
« Reply #32 on: July 03, 2010, 07:33:41 pm »
Here's the drawings
Ok, thanks. Got the picture, too. Smaller than I thought it would be.
Now what?
Logged
Be safety conscious. 80% of people are caused by accidents.
mayfly
View Profile WWW
Ignore
« Reply #33 on: July 03, 2010, 07:44:49 pm »
I've got two completed chassis on the bench.  How about we do two boxes in some kind of groovy wood finish but with 1/2" front and back panels?  The depth of the overall box will have to be increased by 1/2 as well.  One thing that is not captured on the drawings is that the faceplate adds 1/16 of an inch to the depth of the chassis - so overall the chassis is 8 1/8" deep.
Once done, just fire them back up here and I'll do the assembly.  If you like I can send down the handles and the nickel plated expanded metal pieces for you to install.
Clear as mud?
Logged
Marko
I love the chosen one
View Profile
Ignore
« Reply #34 on: July 03, 2010, 07:50:07 pm »
Very Exciting!!!
I want one too! Wink
Logged
Feck Off!
Cagey
View Profile
Ignore
« Reply #35 on: July 03, 2010, 08:42:05 pm »
Clear as mud?
Well...
What would you consider a "groovy" wood? I've got some nice oak and walnut both here now, but have access to all sorts of stuff. You want the whole thing done in hardwood, or just the face, or just the carcass and do a complementary face cover in some sort of tolex-type material? What kind of finish on the hardwood?
According to the drawing, the thing IS 8 1/8" deep. Then, judging by the picture, the front panel is inset a bit, which is not shown on the drawing. For the record, I think it'll make for a better finished look if it is inset a bit.  Also, I'd like to make it just a tad wider, maybe an inch or so, to match up to standard rack width cabinets. Finally, what about the corners? Metal corner protectors kinda take away from the high-end look of a hardwood cabinet, but without them moving the amps around will beat the hell out of exposed wooden corners. What do you think?
Finally, there are no mounting holes called out for the chassis. Do you just run some wood screws in through some ears, or what? Is there a chassis drawing available?
Logged
knucklehead G
Lowering expectations since 1987.
View Profile
Ignore
« Reply #36 on: July 03, 2010, 11:14:21 pm »
Any chance this could be tweaked into a bass head? Like the Ashdown Little Bastard or something, 30W all-tube bass.
Tube noob here, so forgive if that is a horribly silly question.
« Last Edit: July 03, 2010, 11:16:05 pm by knucklehead G » Logged
Anything can be a weapon if you're holding it right.
JaySwear
View Profile
Ignore
« Reply #37 on: July 03, 2010, 11:33:09 pm »
i really really need a new amp... maybe i better start a CageyFly / MayCage amp fund after this next warmoth?
Logged
Cagey
View Profile
Ignore
« Reply #38 on: July 04, 2010, 12:05:53 am »
There's really very little difference between a guitar and bass amp. The tone stack might get tweaked a little bit to change the range, and usually the output is much higher. Humans don't hear low frequencies as easily, so they need to be louder. That's why you'll see the guitar player with a 50 watt amp while the bass player will have 200-300 watts burning, at least with tubes. With solid state, the power will often be even higher than that.
Logged
mayfly
View Profile WWW
Ignore
« Reply #39 on: July 04, 2010, 05:45:25 am »
Clear as mud?
Well...
Kay,
1 - walnut would be great.  some kind of satin clear finish would be fine.  A waxed finish might be kind of nice with lots of grain showing.
2 - I think the entire amp should be wood.  Would be interesting if the front and back panels were a different complementary color (this was kind of the mayfly thing), but not really necessary.
3 - Looking at the drawing again, yep I did include the extra 1/8" - didn't look at it closely last night.  Remember - I drew these almost 10 years ago!
4 - Yep, the front and back panels are inset.
5 - Wider?  sure.
6 - Corners?  Naw - not on a hardwood amp.  Would detract from the look.
7 - the chassis is mounted with blind rivet nuts attached to the chassis and are then bolted from below.  I'll take care of drilling the appropriate holes.
Logged
Cagey
View Profile
Ignore
« Reply #40 on: July 04, 2010, 07:31:18 am »
5 - Wider?  sure.
Alright, that should be as much as I need to know. I'll get started on it this coming week.
Logged
mayfly
View Profile WWW
Ignore
« Reply #41 on: July 04, 2010, 11:22:56 am »
5 - Wider?  sure.
Cool!
er, should we talk price?
Logged
Cagey
View Profile
Ignore
« Reply #42 on: July 04, 2010, 03:36:32 pm »
Certainly not where the kids can hear us. But, I'm thinking $124,285.00 each. After all, amps don't build themselves <grin>
Seriously, I gotta think on it, and right now I'm supposed to be grilling burgers. Some sort of holiday. So, I'll get back to you.
Logged
mayfly
View Profile WWW
Ignore
« Reply #43 on: July 04, 2010, 04:44:18 pm »
Groovy.
Logged
mayfly
View Profile WWW
Ignore
« Reply #44 on: July 17, 2010, 04:55:16 pm »
Folks,
Another used Mayfly BC30 has appeared on the market:
http://www.spacemanmusic.com/Amps/Tube+Amps/Mayfly+BC-30+Head+with+Cabinet
It's priced pretty cheap especially since a cab is included.
Here's yer chance to get one if you want one!
Logged
Pages: 1 2 [3] 4 5
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
Moonraker design by Crip
Some images provided by sloopz.
Valid XHTML 1.0! Valid CSS!
Page created in 9.385 seconds with 18 queries.
