Unofficial Warmoth
Welcome, Guest. Please login or register.
Login with username, password and session length
   Home   Help Search Login Register
News: Check out the new Warmoth Guitars Flickr Pool!
Pages: [1]
  Print
Author Topic: 6 hole trem + tremol-no = ?  (Read 169 times)
rockskate4x
View Profile
Ignore
« on: July 26, 2010, 12:28:45 pm »
Hello, fellas... I love my calaham 6-hole trem and I usually have it set up to float, but I find it annoying when I want to go to drop d or any open tunings. The tremol-no seems like it would be the right solution to the problem but I've only seen them with floyd type trems so far. Are they compatible with 6 hole tremolos, and if so which one should I purchase.
Logged
SustainerPlayer
You've ignored this user ... to no avail.
View Profile
Ignore
« Reply #1 on: July 26, 2010, 01:16:02 pm »
Hi - you find all info here:
http://www.tremol-no.com/workswith.asp
I used a Tremol-no with a Wilky VSVG for alternative tunings a couple a years ago. Worked like a charm.
Logged
"Son, no one gives a shite about all the things your cell phone does. You didn't invent it, you just bought it. Anybody can do that."
AutoBat
View Profile
Ignore
« Reply #2 on: July 26, 2010, 01:31:48 pm »
hipshot tremsetter does about the same thing (if not exactly)
Logged
SustainerPlayer
View Profile
Ignore
« Reply #3 on: July 26, 2010, 02:19:09 pm »
Really not.
The tremsetter returns the trem to "zero" - almost anyhow. Whereas the tremol-no lets you choose between hardtail, dive-only or full floating mode - but it will not inflict on how or where the trem stabilizes in full floating mode.
« Last Edit: July 26, 2010, 02:31:41 pm by SustainerPlayer » Logged
TonyFlyingSquirrel
View Profile WWW
Ignore
« Reply #4 on: July 31, 2010, 03:33:27 pm »
The Tremol-no is not even noticeable if the trem is set up for fully floating.
It's great for double stop bends when you have it set for Dive Only or Hardtail.  You can detune the Low-E fine tuner on a Floyd and go to Dropped-D very quickly and use the bar to dive with and then go back to fully floating once you've re-tuned the string back to E.
When I record, unless on the rare occasion that I have a rythym part that has some bar use, I almost always have it set to hard tail, and the increased resonance is easily noticeable.
Logged
www.warmoth.com
http://www.soundclick.com/bands/pagemusic.cfm?bandID=268162
Seven Strings to rule them all, Seven Strings to find them, Seven Strings to bring them all, and in the music bind them.
http://www.myspace.com/tonyflyingsquirrelmusic
Patrick from Davis
View Profile
Ignore
« Reply #5 on: August 21, 2010, 08:25:51 pm »
Considering what some would spend on other aspects of their guitar addiction, the Tremol-no is not that expensive, and a very eloquent solution to the problem you describe.  It does work as well as advertised, and is well made.  I am going to get one next month for the guitar I am working on with a Floyd.  Good luck
Logged
pabloman
Sr. Member
View Profile
Ignore
« Reply #6 on: August 21, 2010, 10:17:55 pm »
I think the real problem is your bridge itself. You should send it to me and I will send you a Genuine 1957 RI Fender Musical Instruments unit that has been factory tested to perform as designed.
Logged
Pages: [1]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
Moonraker design by Crip
Some images provided by sloopz.
Valid XHTML 1.0! Valid CSS!
Page created in 9.38 seconds with 18 queries.
