MikeW
So the new band is doing a lot of surf stuff. Really fun, but everything I have is either a bit too cool or way too hot for that stinging clean tone that surf is known for. I'd also been wanting to build something with Pao Ferro and had ordered a neck last year. It'd been sitting while I collected parts for a bit and I was finally able to finish it off thanks to the big sale.
Here's the specs:
Neck:
Pao Ferro/PaoFerro
Wizard Profile
Sperzel staggered locking tuners
stainless threaded inserts
LSR roller nut
SS6150 frets
Body:
Alder HSH rout
Wilkinson bridge
Tortioseshell pickguard
Daphne blue
Pickups:
DiMarzio The Chopper in the neck
DiMarzio Steve's Special in the bridge
Super 5-way switch
1. Bridge Humbucker
2. North Bridge Coil
3. South Neck Coil + North Bridge Coil (the inside coils)
4. North Neck Coil
5. Neck Humbucker
I had actually wired the pickguard a few weeks ago when I was stuck inside during a rainy weekend. It went into the 8-Ball for some testing.
I love threaded inserts in the neck. It's a pain getting them installed, but once you do them you'll never go back. You can draw the neck into the pocket much tighter with the machine screws than you can with any wood screws.
Pao Ferro is interesting to work with too. It's sooo hard, but almost brittle in a way. Instead of making dust with very small particulate like Maple or Alder or Ash, Pao Ferro breaks down into flakes. If you look closely at the edges of the holes, you can see where the wood basically flaked apart as I was drilling the holes for the inserts and countersink for the tap.
Sperzel tuners installed and ready to go.
Here's the big pieces, ready for assembly.
I had dropped the pickguard into place and wired the jack in. I took this shot with the neck laying in the pocket as a check for fit.
And Viola! I'll try to get a better picture in the light tomorrow.
I'm calling it the Turtle for a couple reasons. I've now got a guitar for each of my kids, and this one is going to be for my youngest son. His nickname is Turtle. That and the Tortoiseshell pickguard and the sea/surf theme all go together I think.
Here's the specs:
Neck:
Pao Ferro/PaoFerro
Wizard Profile
LSR roller nut
SS6150 frets
Body:
Alder HSH rout
Wilkinson bridge
Daphne blue
Pickups:
Super 5-way switch
1. Bridge Humbucker
4. North Neck Coil
5. Neck Humbucker
