Re-Pete
I was on a reddit forum for a band I follow and the discussion came up about the gear the guitarist's use. I noticed in this band's case that both guitarists use guitars that have the same neck scale length (25"). Previously the rhythm guitarist had played a guitar that was 24.75" neck scale...
I suggested the same neck scale length would help the guitarists be more 'in tune' with each other as the compromises to intonation would occur at about the same place (or be similar compromises made to the harmonics) on each guitar because the neck scale is the same.....
We all know that guitar intonation beyond the root note is compromised..... So that's what I was basing my answer on...
Was I barking up the wrong tree? I'm not sure.... :sad:
I know at times a Strat and a Les Paul can sound horrible together, the chords each make, even though it may be the same chord, sound a bit different...But I was wondering if that was because of the vastly different types of construction and electronics OR the neck scale differences?
